Adding Sirius/XM and Bluetooth and retain factory look?
Old Oct 28, 2019 | 05:13 PM
AP3 has a different meaning for 2009. It means RKE (that they all have) There is no specific code for RVS for 2009-2011.
Old Oct 28, 2019 | 05:19 PM
He did say the fob has the buttons and so , I guess I was off a year.
Old Oct 29, 2019 | 06:10 AM
Klayfish's Avatar
Help me interpret that? RKE and RVS?
Yes, the barcode sticker was there when I bought the car, probably from the rental company. I just haven't peeled it off yet.
So do you think it's possible to add satellite to the car and retain factory look, without too much hassle?
Old Oct 29, 2019 | 07:24 AM
Remote Keyless Entry
Remote Vehicle Start
should be able to add the satellite radio parts and program the ORM head unit
Old Oct 29, 2019 | 09:12 AM
You would need a XM unit, wiring and antenna from a junkyard AND BCM programming from GM. BT would take a OnStar module from a junkyard and wiring. And some know-how
Old Oct 29, 2019 | 09:18 AM
These kits are available at Crutchfield
https://www.crutchfield.ca/learn/two...-your-car.html
I don’t see Chevrolet HHR in the order area, maybe call them
Old Oct 29, 2019 | 09:36 AM
If you want to experiment you could try patching the XV300V1 into the radio plug since the radio does not have a dedicated plug for XM, but there are pins for the XM in the harness plug. Steering wheel controls go through the BCM, so maybe.
"XM/Sirius Ready" means there is a barrel plug on the back of the HU ready for literal plug n play.
Old Oct 29, 2019 | 02:45 PM
PulpFriction's Avatar
If the fob has a remote button and the car has no RVS, the fob may be a replacement. There’s no harm in double checking the setup for a disabled remote start option, though; even if not SUPPOSED to be there in a 2009, who knows for sure what fleet sales would do to land a fat rental order?
Old Oct 29, 2019 | 10:40 PM
Yes, he could scroll through the menus in the DIC to see if there is a RVS option to enable. Or, look for a wire going into the hood latch (not the impact sensor).
Old Nov 14, 2019 | 08:50 AM
I was in my local WallyMart , in the automotive area they had two different kits to add Sirius XM radio to a car. Under $100.00 CAD
