Adding a voltage gauge
Old Nov 15, 2018 | 12:09 PM
Nope a volt meter
This is for an amp meter
Old Nov 15, 2018 | 12:37 PM
I don't know why a voltmeter would need larger wire for a meter than it does for an auxiliary power outlet. An ammeter needs the load bus
Old Nov 15, 2018 | 12:47 PM
I find theses things intriguing, especially how cheap they are.
Old Nov 15, 2018 | 02:34 PM
You are right Donbrew - a voltmeter only measures the VOLTAGE, which doesn't really need a heavy wire. An ammeter measures the used current - measuring the current requires heavier gauge wire, dependant on the current draw being measured.
Old Nov 15, 2018 | 07:34 PM
letterman7's Avatar
Yep, cool little gadgets. In the days when I was building my VW kit cars, if the gauge set I wanted didn't include a volt meter, something like that was always installed (though analog). With the shoddy wiring that was always involved by previous owners, it was nice to see if I had any drop during the course of the day at a show.
Old Nov 18, 2018 | 12:55 PM
dougcjohn's Avatar
Just trade it in for a SS w/ the RPD unit. It will monitor lot's of stuff and has a digital speedometer also. I never even look at the "needle" speedo anymore. Too hard for my old eyes to see.
Sweet! Did the HHR SS all have a HUD, or option? Was it a common option, meaning will you find it in an SS very often.
I had a 01 SSEi with a HUD, enjoyed it!
Looked at a HUD lay on dash add in but wasn't worth a 2nd look.
Old Nov 18, 2018 | 01:36 PM
Standard on 2010-2011, wires are there for 2008?-2009. Not really HUD it sits in the space for the storage bin.
If you really want a HUD get an ELM327 OBD2 device and Torque lite on your smart phone. Set it to HUD and figure how to mount it on the dash. BTW, an old, out of service smart phone works fine.
Old Nov 18, 2018 | 01:47 PM
You could install one if these
ZYOU 5V/3.1A (1A & 2.1A) Dual USB Charger Port Voltmeter Voltage Meter Red LED Display Universal for Car Boat Motorcycle Red
Amazon Amazon
I notice it reads up to 30 volts, hence heavier wire to handle it. It doesn’t just measure up to 12 volts
Old Nov 18, 2018 | 02:07 PM
that's a cool unit - I like that one a lot. the 3rd pic on the left doesn't show the voltage readout display though - kinda weird.
Actually the reason it needs a heavier wire, is that it actually can draw a lot more than just a simple voltmeter due to the fact that it has the USB charger built into it. It has nothing to do with the fact that it can read up to 30 volts. Ie: think of your voltmeter......... the thin measuring leads can measure up into the hundreds of Volts, but a very limited amperage (which is also limited by the internals of the multimeter).
Old Nov 18, 2018 | 03:07 PM
The RPD was an option for 2009 SS, standard on 2010 SS.
