Air Bag Service Light - Intermittent
Old Nov 26, 2019 | 10:01 AM
woodenhead1's Avatar
Unhappy Air Bag Service Light - Intermittent
Aloha everyone,
Have any of you experienced an intermittent Service Air Bag Light message ?
Mine comes and goes, generally occurs on damp/rainy days.
On hot sunny days, no message.
Thx
Old Nov 26, 2019 | 10:08 AM
Radco's Avatar
Aloha and WELCOME to the group !\As for the Air Bag light coming on sometimes Yes it has happened to me a few times. Start the car and does not go off. I shut off car and restart and all is fine ! Has not happened in a while , and If memory serves me right only happened winter time ! I will pay more attention as to weather if it happens again.. Been at least 6 months since it happened last ! I will be following to see the replies as I am really curious now lol
Old Nov 26, 2019 | 10:23 AM
Welcome.
What year model ? There was a TSB or recall regarding an airbag connection or wire harness in the passenger side kick panel. Will depend on your year model and if it pertains to you.
Old Nov 26, 2019 | 10:24 AM
Doc brown's Avatar
This is typically (not always) because you have a loose connection to the seat belt under one of your seats. Make sure all the harnesses under the seats are tight.
Old Nov 26, 2019 | 10:31 AM
Welcome.
I was thinking the same thing, FMG. I believe it was 2009 only, for fretting and corrosion in a connector located behind the passenger kick panel.
Google didn't turn up any results other than this site. Maybe GM isn't doing this recall anymore. I got the notice years ago, glad I took care of it promptly.
Old Nov 26, 2019 | 11:43 AM
Forgot to mention year & model;
2011 LS
Thx, I'll check them
Old Nov 26, 2019 | 04:13 PM
Radco's Avatar
2011 LS
Mine is a 2011 LT
Old Nov 27, 2019 | 02:16 AM
SwissHHR's Avatar
I had the same issue with the air bag light coming on every now and then in 2014. I disconnected the air bag connection plug behind the passenger side kick panel and cleaned all its contacts with electrical contact cleaner spray. The light hasn't come back since.
Make sure to disconnect the car battery before working on the air bag plug.
Old Nov 27, 2019 | 05:24 PM
Cheers, that will be one of my plans for the weekend
Old Nov 27, 2019 | 08:45 PM
Don't touch anything until you wait 25 minutes after battery disconnect. The airbag computer has a capacitor to retain power after shutdown.
