Any way to lower top speed?
Old Dec 18, 2018 | 06:02 PM
Block of wood.
Years ago I had a short term job working on county school buses. Many of the older buses actually had a block of wood bolted on the underside of the gas pedal.
This was the counties idea to slow down some of the speeding bus drivers.
Funny, but true.
Old Dec 18, 2018 | 09:32 PM
Block of wood.
Funny, but true.
I was thinking of mentioning the "old block of wood" governor. It works.
Old Dec 18, 2018 | 10:29 PM
I'm guessing he wants a way to limit the top speed, that the intended driver cannot easily disable.
Old Dec 18, 2018 | 10:37 PM
... that block would work as long as the driver isn't a carpenter .............. :)
Old Dec 19, 2018 | 11:31 AM
I live in a "right to work" state; no unions here. Anyone can touch wood.
Old Dec 19, 2018 | 11:40 AM
Well not not just anybody! He is a Sheriff!
Old Dec 19, 2018 | 06:40 PM
Silverfox's Avatar
The Good Ole Block of Wood sounds good but it has it's short comings as well.
1. How fast do you want to get to the desired speed. You would not be applying 100% full throttle.
2. You would be setting the conditions for that speed by the road and weather conditions based at the time of installation, and if you set it based on a level hiway, the throttle position required may change when encountering any incline or decline so your speeds will vary.
Silverfox
Old Dec 19, 2018 | 07:15 PM
I donno... I raised the speed of mine.
Old Dec 20, 2018 | 08:21 PM
letterman7's Avatar
https://www.carid.com/intellitronix/...iABEgIT5PD_BwE
Limits out to 73 mph
Old Dec 20, 2018 | 09:23 PM
The OP (who has not returned) said he tried that, but 73 is too low and it is not programmable
