Anything diff. from 06 to 07 HHRs?
Old Jun 5, 2008 | 11:40 AM
mudd274's Avatar
Originally Posted by ChevyMgr
The 2007 has water leaks at the cowl which usually leaks into the passenger floor board. It was not very common in 2006 but was an added feature to a lot of the 2007s.
Wonder if I paid more for that feature.
I may not have it because it hasnt started working yet or maybe I need to take TIGGER in for a check up!! and have that creature I mean feature checked.
Old Jun 9, 2008 | 09:23 AM
ChevyMgr's Avatar
GM finally figured this difference out.
Document ID: 2149557
#PIC4261: Dome Lights Are Inop From The IP Dimmer Switch - keywords dim dome feature int intermittent inoperative lamp model on off wheel - (Jun 6, 2008)
Subject: Dome lights Are Inop From the IP Dimmer Switch
Models: 2006-2007 Chevrolet HHR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
This message is to inform you that the dome light (turn on) feature has changed functional operation between 2006 and 2007 Model years. The 2006 Model year operation (to manually turn on the dome lights) was to use the dome lamp switch (in the headliner) and switch it from Door, On, and Off. The 2007 Models use this same feature but in addition can now use the I/P dimmer wheel, if turned all the way to the right. (detent)
Recommendation/Instructions:
Normal operation no repairs are necessary.
tracy waddell
South Pacific
24
Sep 7, 2011 07:29 AM
BlackScreaminMachine
May 31, 2010 11:15 AM
SandyBeach
Sep 19, 2008 05:04 PM
LT1GMC
Apr 6, 2008 08:08 AM
Money in the Bank
Feb 28, 2007 12:29 AM
