Auto Dim Mirror?
Old Jun 14, 2009 | 07:21 AM
  #31
HHROwner's Avatar
Originally Posted by UncleDannie
Thanks a bunch HHROwner, that does help. ChevyMgr posted a diagram of the 16 pinout but I can't find it. It might be on one of the threads. Anyway, Good Luck!
actually let me update -
pin 8 - is common
pin 6 - is the wire from the previous mirror than read .25v
pin 1 - is the 12v+ on all the time
pin 13 - is the autodim/ compass 12v+ switched.
got mine working yesterday and love it. so i have autodim/compass/maplights that dim
Old Jun 14, 2009 | 06:52 PM
  #32
hhr9's Avatar
I ran across this awhile back (not all versions of mirror use all pins)...
1 = Grey = not used
2 = Bare = Microphone
3 = "Passenger Air Bag on" notification (some GM trucks - ground pin to activate)
4 = "Passenger Air Bag off" notification
5 = auto day/night signal from LH outside mirror (use w/ pin 16)
6 = Brown = Temp probe connection
7 = Green/Black = Temp probe connection
8 = Black = Ground (Common to Pin 9)
9 = Light Green = Reverse Dim Inhibit
10 = Gray = Microphone
11 = Dark Green/White = keypad signal (out)
12 = Light Green = keypad +5v supply (in)
13 = Yellow = +12V switched (ignition)
14 = Yellow/Black = Green LED signal
15 = Brown/White = Red LED signal (apply 12v to light LED)
16 = day/night signal to LH outside mirror
Old Jun 15, 2009 | 12:14 AM
  #33
UncleDannie's Avatar
Great! Thanks to everyone for the help. I have two mirrors, one a full auto dimming with OnStar, and one standard mirror with OnStar but has manual day/night. Neither has map lights. I'm putting both up for sale in the classified in about one hour.
Old Mar 3, 2010 | 01:48 AM
  #34
Talvanos's Avatar
Map lights, Compass, and temp on an auto dimming mirror? What part number do I need to order? I wonder if this will fit my 2010. Anyone have an idea?
Old Mar 3, 2010 | 07:22 AM
  #35
Old Lar's Avatar
I enjoyed that option on my last car, but my '06 HHR LT1 did not have that option available and I don't think the '10 LT1 has that as an available option. I think it comes standard with the LT2.
It seems difficult to special order an HHR and get a good deal any more.
Old Mar 3, 2010 | 09:53 AM
  #36
J W Davis's Avatar
mirror
My '08 2LT has onstar, maplites,auto dimm, and compass. Came standard on my package.
Old Mar 3, 2010 | 10:26 AM
  #37
Talvanos's Avatar
wonder what the part # is, and if it will work on my 2010.
Old Mar 3, 2010 | 10:46 AM
  #38
Talvanos's Avatar
ok, for a 2010-2009 Auto dim mirror with Onstar P# is 15787972, and runs $239.80 from GMPartsDirect.com
Old Mar 4, 2010 | 01:50 PM
  #39
jerry455's Avatar
put one in my 09 LS and it plugged right in. I think the part # is the same as a trailblazer. I found one in a junkyard and installed it.
Old Jan 21, 2011 | 04:42 PM
  #40
snoftall's Avatar
OK, I looked on the back of my new mirror, but there is no GNTX number. I also see that there are several sensors and an unknown module on my newest mirror. I have taken a couple of photos, hopefully, someone may be able to shed some light on what I have.
This is the front of the mirror. Note the green sensor on left side, also, the other two LED just show power to compass and OnStar on.
Note the module on stalk. This contains a circuit board and is hooked up to internal board of mirror. Have no idea what it's for.
Windshield view of module. Everything works EXCEPT for the pair of map lights.
Did anyone ever figure out the GM part number for the mirror pictured above? I'm looking for this exact mirror with the Auto Dim feature along with OnStar, Map Lights, and the Compass. I have a mirror here in front of me with GM part number 15787972 and it does not have map lights. It also has the light sensor in a different location (In the top center of the mirror) rather then down to the left of the power button like the one pictured. The one I have here also seems to have the compass equipment inside of the mirror, rather then stuck to the mounting base like in the picture above.
