Auto Govern
Old Dec 19, 2008 | 03:59 PM
HHR SS Black's Avatar
Auto Govern
So i have the ss auto, I have only been able to get it to 130-132ish, It doesnt want to shift into fourth. Is it built to do this?
Old Dec 19, 2008 | 05:08 PM
prod's Avatar
Shouldnt be a problem, maybe you should get it checked out.
Are you in "I" instead of "D"?
Old Dec 19, 2008 | 05:54 PM
ChevyMgr's Avatar
Limter is set by tire speed rating.
Old Dec 24, 2008 | 06:36 PM
No, I am in The D position. The tires are the Michelin Piolts 225 45's. I tried again today and same. What have you other guys in the autos hit?
Old Dec 24, 2008 | 09:04 PM
Tim S.'s Avatar
I have had mine up to 125-130'ish and it seem to have alot left.
Old Dec 24, 2008 | 10:00 PM
wysguy's Avatar
Please correct me if I'm wrong, but doesn't the SS come with "Z" speed rated tires? (point being, they're rated for "in excess of 149 mph")
Old Dec 25, 2008 | 12:07 AM
halfpanel08's Avatar
ive never gone over 100 n my hhr.. surprisingly .. cause ive done 120+ n past cars
Old Dec 25, 2008 | 12:15 AM
stephenm's Avatar
it's governed at 130 through the ECM i believe
Old Dec 25, 2008 | 04:06 PM
IgottaWoody's Avatar
If its like any other GM product..once you pass 3/4 throttle position your locked out of 4th..another way to look at it..your in passing gear! You might be able to install a bypas switch to the lockup converter so it works in 3rd which will give another 200 rpm or so unless it requires (and probably will) a tuners help to reprogram it.
Old Dec 25, 2008 | 04:47 PM
Chevy SS's Avatar
It's a great feeling knowing that you are at the limit of your tires, lol. Haven't done much in the SS, but I have done 135 MPH in an STi and 120 MPH in an Evo MR during a test drive :)
