Blowing air vents...
Hello,
Even when i turn off my air i still get quite a bit air flowing through the vents. At a stop a little air blows through, but while driving quite a bit blows through. To turn off the vents i just turn the fan switch all the way to the left...correct? I know i could set it so that it blows out somewhere else like the defroster, but should it keep air flowing with everything turned off? does everyone elses continue to blow as well?
Thanks,
Greg
Thanks,
Greg
You probably have it set to fresh air. As you speed up air is pushed into the outside fresh air intake on the cowl and into the car. At a stop wind can do the same thing. If you want to stop the air flow completely just set it to recirculate. Every car I have owned has done this.
frank kaminski
Sep 7, 2014 08:53 AM
