Brake and blinker light problem.
Old Dec 2, 2025 | 03:17 PM
alweasel's Avatar
Exclamation Brake and blinker light problem.
Hello All.
I had my driver side blinker light put in a couple weeks ago and now that and my brake light are out. I replace the brake light this summer.
What are easy things that even a car idiot could check. My car guy is checking it on Thursday but I would like to see if it's expensive or not.
All other lights are fine.
Thanks for all your help, I appreciate it.
Al
Old Dec 2, 2025 | 06:09 PM
Could be as simple as the wrong bulb was installed. Your 2009 has 3157 in the front signal and 3057 in the rear brake light. You need to check the ground wires also.
Old Dec 2, 2025 | 06:10 PM
You can also inspect the fuses push them all into place firmly, here’s a map of what fuse is where
https://fuse-box.info/chevrolet/chev...uses-and-relay
Old Dec 4, 2025 | 11:12 AM
alweasel's Avatar
Thanks. I have my guy looking at it. I gave him the fuse box info.
I appreciate it. I will let you know what he found.
Thanks Al
Old Dec 4, 2025 | 11:50 AM
alweasel's Avatar
my guy figured it out and fixed it for $125.00. The wires in the back blinker and brake light were burnt in the rear bumper.
Old Dec 4, 2025 | 11:54 AM
The brake light is the same as the turn light, the same filament. If one is out so is the other, or a switch is bad.
If it was a bad ground the tail light would also be out, they all share the same ground.t
The 3 functions are in the same bulb, the brake and turn are one filament and the tail light is the other.
Did you replace the bulb or did somebody else? Did whoever look at the contacts in the receptacle? Was the bulb firmly seated? Was there corrosion on them?
Do you know that DRL is head lights only, no tail lights?
Old Dec 4, 2025 | 12:45 PM
Glad he found the problem and fixed the harness.
Old Dec 4, 2025 | 03:29 PM
Did he fix whatever caused the burning?
Old Dec 4, 2025 | 06:24 PM
That’s the burning question!
Old Dec 8, 2025 | 03:05 PM
alweasel's Avatar
I dont remember what caused the burning. I am thinking the ground but not sure. Next time I see him I can ask him.
10 uh C cozydog
Jun 25, 2022 07:33 PM
Arnolds Barber-Salon
Jan 21, 2021 10:00 PM
swerv0428
Mods - Exterior
12
Aug 10, 2012 09:43 AM
tomw
Jun 7, 2008 06:09 PM
dadd75
May 3, 2007 07:47 PM
