Buzzing in top plastic door panels from stereo
Does anyone else notice a buzzing from the plastic door panel tops with mid levels of volume? I have the Pioneer system so that probably is some of the problem.
Can I put something in there to stop it? Simply touching the door panel stops the buzzing.
I've never noticed that althought Marie drives the HHR a lot more than I do.
I do have a couple of suggestions you can try though:
1) Turn the radio down! The loud music is rattling your car apart.
2) Turn the radio up! You'll never notice the rattle if you turn the music loud enough.
i have had the radios at a lot of levels, usually listen to it really loud, an i haven't noticed any rattles or bussing from it. Had the bass up all the way testing it out the other night and nothing from that either.
