Cargo Net
Cargo Net
Found out I didn't have the factory cargo net for the back of my Panel. I bought a similar item from Walmart but it did not work at all. I found a factory net on eBay for $9.99 (+ shipping) so I bought it. It was dirty
but cleaned up nicely. No rips or tears so it's into the back it goes. All cargo stowed & secure sir!
The two middle hooks go just above the two inside and the two hooks closest to you go on the rings just inside the door! Kind of makes an "L" shape! Don't have pics right now! The end result is you can put groceries and other stuff without it sliding around!
I'll take pics if needed,
I always use mine flat, tied to the 4 corner points when picking up a case of beer from the beverage center. Don't want it to slide around too much, because by the time you get home, it's all foam when you open up a can while polishing the HHR.
