Center Caps for Steel Wheels?
Old Mar 29, 2010 | 09:28 AM
Gone Blue's Avatar
I have been running 16" steel HHR rims with the bolt on stock hub caps and winter tires on my SS the past two winters. While looking for a different look next winter, I am wondering if anyone knows if the following center caps will fit the HHR steel rims?
S10 bolt on center caps
Impala police car center caps
Chevy Beretta center caps
The S10 caps use the same plastic nuts to bolt the center caps onto the lug nuts. The Impala center caps use three seperate screws to attach the center caps to the wheels. I dont know how the Beretta center caps mount. I think the diameter of all these caps would fit the HHR wheel. I just dont know about the lug pattern.
Thanks, G.B.
Old Mar 29, 2010 | 11:04 AM
Gone Blue's Avatar
With a little research I think I answered my own question.
Beretta 5x100
Impala 5x115
S10 5x120.7
It is not looking like this will work. I am now thinking about seeing if push thru center dust caps might be an option. I need to measure the center hole diameter on the 16" steel HHR wheel to see if this might be a way to go.
Hmmmmm. This post might also bave been better in the Wheels & Tire section.
G.B.
Old Mar 29, 2010 | 03:52 PM
Blue-
"I am now thinking about seeing if push thru center dust caps might be an option".
With the hub-centric rims, I doubt there will be room for anything but the hub flanges..
But that's just my keyboard guess..
Old May 31, 2014 | 11:53 AM
bowtieboy68's Avatar
trying to revive an old thread:is there a cap that will push OVER the center flange on the steel wheel?
Old May 31, 2014 | 12:16 PM
No tabs on the steelies.
Old May 31, 2014 | 12:20 PM
i'm attempting to find something that pushes on the center part of the steel wheel (2 1/4" hole).
not going well
LeoVG
Tires & Wheels
Jun 2, 2015 08:07 AM
imageauto
Tires & Wheels
29
Feb 18, 2012 03:00 PM
Joepoppa1
Nov 7, 2011 03:53 PM
MetallicaMatt
Nov 18, 2008 10:17 PM
