CGS cold air intake
Old Aug 14, 2010 | 10:11 PM
jolinker1's Avatar
CGS cold air intake
Hi, my name is Joe. I recently purchased a CGS cold air intake for my 2007 2.4L HHR. When the car is parked and i rev up the engine, it will climb to 4,000 rpm and then will not go higher. It sounds like it just starts to choke or something. One import tuner guy told me to disconnect battery and then connect after 20 seconds. He said it will reset the ECU in the car and then told me i had to take the car to a straight away and get it at high speed and rpm to fix the problem. Does anyone have a clue as to why my HHR does this?
Old Aug 14, 2010 | 10:56 PM
crazy_urn's Avatar
resetting your ECU is a good idea. don't know if it will fix the prob or not. but reset it and take it for a test drive and see if it helps.
Old Aug 15, 2010 | 08:05 AM
JoeR's Avatar
You are probably and auto trans.
Rev limiter is set to 4,000 RPMs when in park or neutral.
Resetting the ECM is BS. All that does is reset the fuel trims. It will learn back or learn for changes either way.
Old Aug 15, 2010 | 08:39 AM
XtremeModifier's Avatar
Yeah, resetting the ECM helps in some cases (reset fuel trims, clear codes after fixing or if you have too many codes and want to find the initial code/problem) but as he said the limiter is set to 4k. No codes? Run fine when in gear?
Michael20832
2.0L Performance Tech
Jul 8, 2009 05:16 PM
Geoff
May 30, 2009 08:21 AM
Maroon06
2.4L Performance Tech
11
Oct 22, 2006 07:20 PM
