Change clock time
Old Jul 12, 2020 | 12:25 PM
rodr2u's Avatar
Change clock time
I keep trying to change the time on mr clock, but the clock button does not work or change to the hr/minute settings.
Any suggestions?
Old Jul 12, 2020 | 12:45 PM
Hi rodr, to the forums!
Try carefully pushing the face of the radio in.
Old Jul 12, 2020 | 12:53 PM
Is the key in the ignition turned to ACC or Run, is the radio turned on ?
if you need an owners manual, let me know I’ll post a link for you.
Old Jul 12, 2020 | 01:01 PM
rodr2u's Avatar
Yes, the key is in the "On" position, and the car is in "Park", but pressing the "Clock" button listed in the Owner's Manual doesn't change to let me adjust the time.
Old Jul 12, 2020 | 01:07 PM
Last resort, pull the fuse, and reinsert it at noon.
Old Jul 12, 2020 | 01:41 PM
Are you holding the clock button until something flashes or a reasonable time?
Old Jul 12, 2020 | 02:14 PM
Page 4-61 in the owners manual for your 2010
Setting the Clock
Without Date Display
AM/FM Base Radio with a Single CD Player
To set the time:
1. Turn the ignition key to ACC/ACCESSORY or ON/RUN. Press O to turn the radio on.
2. Press H until the hour begins flashing on the display. Press H a second time and the minute
3. While either the hour or the minute numbers are
flashing, turn f to increase or decrease the time.
4. Press H again until the clock display stops flashing to set the currently displayed time; otherwise, the flashing stops after five seconds and the current time displayed is automatically set.
With Date Display
Radio with CD (MP3) and USB Port, and Radio with Single CD (MP3) Player
To set the time and date:
2. Press H and the HR, MIN, MM, DD, YYYY (hour, minute, month, day, and year) displays.
3. Press the softkey located below any one of the tabs that you want to change.
4. To increase the time or date do one of the following:
Press the softkey located below the selected tab.
Press ̈ SEEK, or \ FWD. Turn f clockwise.
5. To decrease the time or date do one of the following:
Press © SEEK or s REV. Turn f counterclockwise.
To change the time default setting from 12 hour to
24 hour, press the H button until 12H or 24H is displayed. Once 12H or 24H is displayed, turn
the f knob to the desired option to select the setting.
Press the H button again to apply the setting, or let the screen time out.
4-61
Old Jul 12, 2020 | 02:49 PM
The radio does have to be on to set the clock...
Old Jul 12, 2020 | 05:08 PM
That’s in the instructions
Old Jul 12, 2020 | 05:14 PM
Well, now you'll have to wait until midnight. Or noon tomorrow.
