Changes from '06 to '07 to '08?
Old Dec 19, 2007 | 08:46 AM
captain howdy's Avatar
Originally Posted by SgtBeavis
The Window switches are no longer on the center console. They are on the door armrest where they have always belongs.
Only on the SS models.
Old Dec 19, 2007 | 09:03 AM
solman98's Avatar
Only on the SS. Not sure if we've concluded this is so on the SS Auto yet though?!?
I'm wonding that also. They stated the switches moved due to the new 5 speed. So with the auto?
I though they would move all to the doors to just cut the cost of having two setups.
Old Dec 24, 2007 | 10:37 AM
lordairgtar's Avatar
Originally Posted by terry44030
The '07 has the plastic fender guard, too. That was removed on the '08's. Also, the Amethyst color was deleted for '08.
My 07 has the clear sticker where the guard used to be.
Old Dec 24, 2007 | 12:20 PM
number47's Avatar
Geeze, we're still complaining about the window buttons?
I did, too, but after the second week with the car, I forgot that switches were ever on a door at all. Now, 29,000 clicks later, it seems like they should all be there....
Old Dec 24, 2007 | 06:19 PM
Old Ray's Avatar
changes to 06 07 08
2006 2007 2008
Add dome light switch
Daytona blue added
Golden teal met. Added
Ebony interior added
(from saginwgn)
Satin exterior package n/a
2.2 different 2.2 different
Steering wheel buttons changed
(from rudeinc)
Plastic fender guards clear thin fender guards
(from lordairgtar)
Onstar standard
Changed coil on 2.2 ?
Tunable ECM
(from rudeinc)
Add body colored mirrors, door handles, and beauty bar.
(from hillsdalehhr)
New rims
(from jx3)
Panel version, rear windor delete option, SS model.
(from hillsdalehhr
Gen II Engine Block
Cylinder Head Improvements
New Camshaft Design
E37 Engine Control Module
58X Crankshaft Reluctor Ring
Digital Crank and Cam Sensors
Individual Coil-on-Plug Ignition
Vented Starter Solenoid
New MAP Sensor
New Intake Manifold Seals
New Oil Filter Element
Improved Emissions Performance
(from PG318 & http://media.gm.com/us/powertrain/en...New/07_L61.doc)
2006 2007 2008
Tire pressure sensors.
Traction control button on dash.
SS 2.0 turbo.
(from TomsHHR)
Turn signal DRL Headlight DRL
(from solman98)
Amethyst deleted.
(from terry44030)
Door window switches
On SS.
(from sgtbeavis)
Last edited by Old Ray; Dec 26, 2007 at 12:03 PM. Reason: Mods: Was to be chart, didn't mean to send, delete it?
Old Dec 25, 2007 | 11:53 PM
  #26
Originally Posted by Old Ray
Daytona blue added
DBM......an original color, also first production year color only (to date). 07 introd the Imperial Blue, and 08 added Blue Flash.
Old Dec 30, 2007 | 12:04 PM
  #27
Power Window Switches moved to door handles for '09.
Old Dec 30, 2007 | 12:43 PM
  #28
an08HHR's Avatar
Hope you mean door panels and not handles. Knew the 09 was getting new make-over, hear anything about the body design?
Old Dec 30, 2007 | 12:55 PM
  #29
Handles, panels, armrest. You get the idea
Old Dec 30, 2007 | 12:59 PM
  #30
prod's Avatar
08 has Onstar standard, so does that include the auto-dimming mirror with map lights and compass? Mine has it.
Also, I thought the running boards were standard in 08. At the dealership there was another blue 08 without them.
