Compatibility yrs to yrs
I am going to be adding a rear seat to my 08 HHR panel.
Just curious, what years will fit, did they stay the same or where there changes from year to year? Just need to know which years to look at when I start calling the yards. Thanks, Michael |
Should be the same for all years. Good luck with swap and welcome to the site!
Other than color and fabric, they are no changes except for the window switches.
Originally Posted by solman98
(Post 698145)
Interior wise the only changes were the window switches and interior colors/fabrics. Exterior was just colors. Drivetrain however had a ingnition/coil change going in 07 from the 06 model. Then later in either 09 or 10 there was VVT added to the 2.2l. I think I am missing one more engine change but someone else will have to post it if there was one. |
Originally Posted by 07azhhr
(Post 698154)
Just to clarify for Sol.
Interior wise the only changes were the window switches and interior colors/fabrics. Exterior was just colors. Drivetrain however had a ingnition/coil change going in 07 from the 06 model. Then later in either 09 or 10 there was VVT added to the 2.2l. I think I am missing one more engine change but someone else will have to post it if there was one. But yes, not much changed period over the years. |
The OP was talking about the rear seats only but you then mentioned the switches too so I furthered that with the other items.
Originally Posted by twinbin
(Post 698060)
Just curious, what years will fit, did they stay the same or where there changes from year to year? Just need to know which years to look at when I start calling the yards. Thanks, Michael Good luck with your conversion. |
(Post 698060)
Just curious, what years will fit, did they stay the same or where there changes from year to year ? That'll save ya some $$$... |
Originally Posted by sleeper
(Post 698247)
When you find your seat, & if you can pull it yourself.. Grab the seatbelts & ALL the bolts, also a small plastic piece of floor that goes behind the seat on wagons.
That'll save ya some $$$... OP what color is your interior. I have the bins that Sleeper is refering to and the load floor that I am no longer using in the LT Grey color. |
