Compatibility yrs to yrs
Old Mar 26, 2013 | 08:05 AM
twinbin's Avatar
I am going to be adding a rear seat to my 08 HHR panel.
Just curious, what years will fit, did they stay the same or where there changes from year to year?
Just need to know which years to look at when I start calling the yards.
Thanks,
Michael
Old Mar 26, 2013 | 08:11 AM
SmootHHR's Avatar
Should be the same for all years. Good luck with swap and welcome to the site!
Old Mar 26, 2013 | 12:34 PM
solman98's Avatar
Other than color and fabric, they are no changes except for the window switches.
Old Mar 26, 2013 | 01:02 PM
07azhhr's Avatar
Just to clarify for Sol.
Interior wise the only changes were the window switches and interior colors/fabrics.
Exterior was just colors.
Drivetrain however had a ingnition/coil change going in 07 from the 06 model.
Then later in either 09 or 10 there was VVT added to the 2.2l.
I think I am missing one more engine change but someone else will have to post it if there was one.
Old Mar 26, 2013 | 01:13 PM
solman98's Avatar
Are we talking as a whole now, or just interiors?
But yes, not much changed period over the years.
Old Mar 26, 2013 | 01:42 PM
07azhhr's Avatar
The OP was talking about the rear seats only but you then mentioned the switches too so I furthered that with the other items.
Old Mar 26, 2013 | 09:08 PM
VinceP's Avatar
Thanks,
Michael
Welcome to the sight! Seats will be the same. I added a rear seat to my 08 Panel and cant remember which year the donor came from exactly but I want to say it was a 2011. In my case the fabric was exactly the same.
Good luck with your conversion.
Old Mar 26, 2013 | 11:48 PM
Just curious, what years will fit, did they stay the same or where there changes from year to year ?
When you find your seat, & if you can pull it yourself.. Grab the seatbelts & ALL the bolts, also a small plastic piece of floor that goes behind the seat on wagons.
That'll save ya some $$$...
Old Mar 30, 2013 | 02:00 PM
07azhhr's Avatar
I pulled mine out and man was it a bugger. I kept thinking how much I wanted to smack the person who designed/decided on that seat . They should have given it either a lock or seperate halves. That frame is heavy enough but then each side swings independantly of one another and cant be stopped while carrying it.
OP what color is your interior. I have the bins that Sleeper is refering to and the load floor that I am no longer using in the LT Grey color.
angus49
Tires & Wheels
Feb 17, 2015 03:31 PM
gwizz
May 24, 2010 11:13 PM
misterjensen
Sep 14, 2007 08:27 PM
