Control arm LS panel 09
Having trouble finding the right control arm for a 2009 LS panel. Found some RK 620301 And RK 620302 moog. Rock auto says they will fit but some sights say they won't. Any info would be nice. Thanks
Those are the stamped steel control arms. The originals are aluminum and it's recommended that you replace them with the same type.
While the steel ones may fit and some have used them, I wouldn't.
Did you look at our Common Used Parts sticky ? Pretty good info on there.
https://www.chevyhhr.net/forums/comm...-thread-48833/
Look here and put in the 5% discount code also.
https://www.rockauto.com/en/catalog/...trol+arm,10401
hhr06NJ
Aug 9, 2018 08:32 AM
Goose
May 30, 2007 07:11 PM
