Coolant Gauge Problem
Old Jan 14, 2007 | 12:07 PM
HHRXM's Avatar
While driving today my coolant gauge flat lined. The DIC also stopped displaying the coolant temp. The car is running normal, plus all other system , gauges are working normal. The DIC is also displaying all other information normally. I have checked all fuses, hoses, etc. Everything seems fine. I will make an appointment with the dealer tomorrow. I was just wondering if anyone else had run across this problem? If so, is there some easy fix that I've overlooked?
Thanks to all who reply.
Old Jan 14, 2007 | 12:59 PM
Snoopy's Avatar
I believe another member mentioned this problem also. Don't remember who. Sounds like a sending unit went bad or a loose wire/connector.
Oh, remind the dealer the HHR has 2 sensors....both need to be checked.
Old Jan 15, 2007 | 06:03 AM
jshandra's Avatar
That would be me. They replaced the BCM and that fixed the problem. It sounds simple but it took them 4 days and 2 revisits to figure this out. Good luck.
Old Jan 15, 2007 | 07:26 AM
oneton's Avatar
If both the gage and DIC temp are inopt. I would say BCM bad or poor connt. at BCM
Old Jan 15, 2007 | 10:13 AM
HHRXM's Avatar
Thanks for the reply's I have an appointment scheduled for tomorrow. The crazy thing is while driving to work today about half way there (10miles) the coolent gauge and the DIC coolent readout suddenly started working normally again. I'm sure that they will both work fine while at the dealer!!
Old Jan 15, 2007 | 08:46 PM
crazybob's Avatar
Had the same issue. After replacing the fan relay and thermostat, it turned out to be a chafed wire in the harness. Only took six trips to the dealer...
Old Mar 20, 2011 | 11:21 PM
chevyorange's Avatar
Do you know roughly where that wire was?
lw9090
Oct 5, 2015 01:21 PM
Wifes07LT
Sep 3, 2013 08:44 PM
cwalker
May 18, 2008 01:23 PM
HHRXM
Jan 18, 2007 12:58 PM
jshandra
Oct 28, 2006 03:32 PM
