Deer Hit, Ouch!
Old 10-21-2018, 09:47 AM
Originally Posted by fastsuv
Thanks for the suggestions.
Luckily the deer didn't flip up and into the windshield, I had two daughters with me.
I need to pull up and sideways on the drivers side, maybe at 30 degrees from horizontal.
First I am going to try the 8000lb $30 come-along from HF. My pole barn has massive vertical timbers so I will attach to that.
If that doesn't work I may try the hydraulic kit from HF along with the pull ram.
Steve
Hope you have some way to anchor the car to the ground. If not, it may start lifting the car and "twist" on the unibody. Gotta be careful when trying to bend structural parts back into position.
I'm with Oldblue on using the Porto Power. Have used a set before on a crushed in tailboard on a truck. Worked like a charm.
firemangeorge is offline
Old 10-21-2018, 10:59 AM
Technical Moderator
These dimensions may be of use. The "upper tie bar" is replaceable, if you need it I have the procedure.
donbrew is offline
Old 10-21-2018, 11:42 AM
Cat Man HHR's Avatar
: Hope you have some way to anchor the car to the ground. .
I gave him that suggestion in post #6.
Don that info on post #12 is very useful.
Cat Man HHR is offline
Old 10-21-2018, 12:29 PM
fastsuv's Avatar
Thanks for the further advice, guys.
Don, thanks for the dimensions. I have the factory service manual but you saved me the trouble of looking it up.
Yesterday when I measured the diagonal dimension that you show as 1374mm, there was a difference of about 3/4 inch from one diagonal to the opposite diagonal. The two diagonals were identical on my other HHR that I used as a baseline.
I am headed to HF now to get some stuff. I have wanted to get the Porto-Power for a while, this gives me a good excuse to buy one :).
Steve
fastsuv is offline
Old 10-21-2018, 12:43 PM
fast
post pictures of what you are doing
Old 10-22-2018, 07:12 AM
fastsuv's Avatar
Originally Posted by Oldblue
A kit like this is a great tool for putting that back to position
HF sells a 4-ton model ($104 after 20% off coupon) or a 10-ton model ($160 after coupon).
What do you think? Is 4 tons enough? I know HF ratings can be optimistic sometimes so maybe the 10-ton model would be better.
Steve
fastsuv is offline
Old 10-22-2018, 08:03 AM
More is better!
Oldblue is offline
Old 10-22-2018, 09:22 AM
Technical Moderator
Depends on what you might use it for in the future.
donbrew is offline
Old 10-22-2018, 12:01 PM
If you use that ram where are you going to push from? Are you going to remove the top radiator brace and just push out the drivers side upright ?
Old 10-22-2018, 03:57 PM
fastsuv's Avatar
I'm not sure yet. I am going to look at it tonight to see what's where.
If there is no way to push, then I will buy the pulling ram with hooks at both ends (picture a few posts above) and pull.
Steve
fastsuv is offline
Quick Reply: Deer Hit, Ouch!
