disable alarm system
Old May 30, 2008 | 06:48 PM
mudd274's Avatar
oh I see that one. I was thinking about one that blinks all the time like some cars do.
Old May 31, 2008 | 12:42 PM
saltyfishguy's Avatar
man I wanna 3lt........
Old Jun 1, 2008 | 11:30 AM
mudd274's Avatar
Quote:
Originally Posted by Snoopy
Yes and Yes on my 06' 3lt HHR.
Quote:
Originally Posted by ChevyMgr
Huh?
What has your 3lt got that my 2lt might want?
Old Jun 1, 2008 | 11:50 AM
one more lt
Old Jun 1, 2008 | 11:59 AM
Snoopy's Avatar
Huh?
Class !!!!
Actually, I had a slip of the finger (or a brain fart, at my age) . Give me a break, I'm on vacation....sitting on the beach in Hawaii.
Old Jun 1, 2008 | 12:17 PM
ChevyMgr's Avatar
How was the HHR riding the waves on the way over? Big Kahuna may be interested in this.
Old Jun 1, 2008 | 01:12 PM
aah111's Avatar
I use this procedure to lock my HHR and not arm the alarm.
1) Turn car off and remove key from ignition.
2) Lock all doors with the door lock button (on the door)
3) Lift the driver's side door lock pin.
4) Get out and manually lock the driver's door.
-Alan
Old Jun 2, 2008 | 11:02 AM
louiemcfarland's Avatar
OK... let me be clear. Unlike "sunset" (post #1) who wants the lock the car using the driver door lock button "without setting the alarm" (which by the way IS the way my 2008 HHR 2LT functions)... I DO want the alarm to be armed when I press the driver door lock button! (like my older 2006 model did). Maybe I’m in the wrong thread (disable alarm system)… I want to ENABLE the alarm system!
I don't understand "aah111" (post #17) method to lock without arming alarm. My doors lock WITHOUT the alarm being set just by normal procedure: turning of the car, remove keys, open driver door, lock using door lock button, get out (if not already out), and close the door. (No need to pull/push door lock pin)
Does anyone with a 2008 HHR have the ability to set the alarm using the driver door lock button? (if YES, please verify... see my post #3)
Old Jun 2, 2008 | 11:47 AM
ChevyMgr's Avatar
That's not possible from the current set-up. The BCM needs to see the switch operate or the key fob in order to set the alarm. It doesn't see manually locking the rod or using the key since there is no flow of current.
Old Jun 2, 2008 | 01:15 PM
When I stated "door lock button" I was referring to the door lock switch on the side of the door... not the "rod" or "using key". (I'm trying to make myself clear, sorry for the confusion)
TO CLARIFY, a here is a re-write of my post #18:
OK... let me be clear(2nd try). Unlike "sunset" (post #1) who wants the lock the car using the driver door lock switch "without setting the alarm" (which by the way IS the way my 2008 HHR 2LT functions)... I DO want the alarm to be armed when I press the driver door lock switch! (like my older 2006 model did). Maybe I’m in the wrong thread (disable alarm system)… I want to ENABLE the alarm system!
I don't understand "aah111" (post #17) method to lock without arming alarm. My doors lock WITHOUT the alarm being set just by normal procedure: turning of the car, remove keys, open driver door, lock using door lock switch, get out (if not already out), and close the door. (No need to pull/push door lock pin)
Does anyone with a 2008 HHR have the ability to set the alarm using the driver door lock switch? (if YES, please verify... see my post #3, but know I mean door lock switch (not door lock button))
