Do you think the HHR could handle towing a 4X8 U-haul Enclosed Trailer?
I'll still tow with mine, the unibody is the same reguardless of manual or auto. The only reason they don't want you to tow with the manual is the clutch. Most people have no clue how to do it correctly with a manual. It's not very often I hook my trailer up, but I will with no second though. No warranty anymore, so I pay for all repairs. Clutch is holding up extremely well, still pull hard.
But I still would not exceed the 1,000 lbs capacity for towing. Heaviest I've every hauled on mine is my 4x6 tilt trailer with my old 38" Murray riding mower on it when I sold it.
The trailer is a 4x6 featherlight tilt, so no rear loading ramp needed. Both combined, I'd probably guess 500 lbs. Never weighed either to be honest. Ony other thing I really use it for is trips to Home Depot or Ace Hardware for lumber and such.
It sounds like all you really need outside your car is your Moped. Get the smallest, lightest trailer you can find. $200 for a transmission cooler plus trailer rental? I might sell the Moped and buy another on the other end before I'd do that. Or ride it there
Goetylsd.. I got my 4x6 tilt trailer from Tractor Supply and they have stores in Wisc. Mine, according to their site only weights 275# and would be cheaper to buy than rent, esp if you ever needed it again. This is the one I have. http://www.tractorsupply.com/vehicle...pacity-1011070
You may want to see if your State requires a plate on it.
One additional consideration that I think has been ignored is the terrain of this trip. Towing that size trailer loaded will be quite different on flat terrain vs hilly terrain vs mountainous terrain. Obviously, the tranny and engine will work a lot harder on any terrain which isn't flat. You brakes will also have a lot more work to do when going down hills.
If the roads are in fairly rough shape with considerable dips/expansion joints that will put a lot stress and strain when the HHR and trailer bounce. Depending on how much weight is actually on the tongue and hitch I'd be concerned with really stressing the frame where the hitch is attached.
Your biggest issue isn't the weight as much as its the frontal area of the trailer. Its like holding up a piece of plywood and running head on into the wind. The HHR has a pretty low towing capacity to begin with. Towing a box is only stressing the car that much more. Anything with a box I would avoid like the plague. The HHR just isn't made for it.
Tikker
24
Jul 20, 2018 03:23 PM
