Does my exhaust look bad?
Old Apr 24, 2024 | 10:15 PM
hhrumadbruh's Avatar
You'll want to cut off the old flex pipe, slip the new one on with significant overlap. Then reinstall, and a few tack welds. Then remove it, weld it up, and reinstall.
dang the local welder aint gonna be cheap if I do that!
Old Apr 25, 2024 | 10:08 AM
greg8453's Avatar
Bring us the pipe and we do it for 20 smackers. Takes less than 5 minutes.
Old Apr 25, 2024 | 10:12 AM
The new flex pipe or repairing the stock setup?
Old Apr 25, 2024 | 10:15 AM
Along drive to get a pipe welded!
Old Apr 25, 2024 | 04:19 PM
WoodysMobile's Avatar
R & R
Visual fail for smog.
JB welded and tried to pass Cali smog with plastic PCV elbow repair on 2003 Camry.
Didn't pass visual they considered it "altered" dealer item only
Latest CA smog adventure was the van with a transmission code intermittent set P1080 finally got it.
Old Apr 25, 2024 | 10:20 PM
greg8453's Avatar
Broken at the flange we repair the flange. If the pipe is compromised we say replace.
Old Apr 26, 2024 | 09:17 AM
The oic shows the inside of the flange is broken, as is the usual. There are as few options; one of which can be clamped on (depending on local law).
CA has some oddities, you might have to get a whole catalytic converter from GM to satisfy the inspector.
PVC in an exhaust system? It starts melting at around 120F.
Old Apr 26, 2024 | 10:29 AM
I'm pretty sure the smog guy never looked at it. Don't think any of them ever have. At most an exhaust fume detector in the engine bay. Don't think they even did that though. My best guess is a pressure rating at one of the 02 sensors that was low.
Old Apr 26, 2024 | 01:36 PM
It's a loss of metered air, but wouldn't that cause a CEL?
Old Apr 27, 2024 | 04:58 AM
PulpFriction's Avatar
I think the right welder could fix that.
