Door check
Old Aug 7, 2017 | 08:14 PM
Hmmm... I'm seeing some more numbers.
25800726 shows as front required:2
Chevrolet HHR Hatchback DOOR HARDWARE/FRONT PART 1
15837416 and 25875215 show as rear required:2
Chevrolet HHR Hatchback DOOR HARDWARE/REAR PART 1
EDIT: HellsHotRod has probably seen a number of these, maybe he can clear this up.
Old Aug 7, 2017 | 09:59 PM
skyline26's Avatar
i probably wouldnt use a used part..
Old Aug 8, 2017 | 12:20 PM
You already are using used parts! Nothing wrong with recycling a piece from a parted out HHR
Old Aug 8, 2017 | 12:57 PM
Not to mention they seem to be made out of gold!
Old Aug 8, 2017 | 03:13 PM
Platinum!! Will do!!!!
Old Aug 13, 2017 | 04:42 PM
  #26
GN1220's Avatar
I found 6 fronts at one of my local U Pull yards. Not sure if there is any difference other than the metal plate on the fronts but it is worth noting. And also they are the same for both sides, meaning the driver side and passenger are the same, only turned over. Score of my Saturday for $1 each!
zip
Jan 27, 2013 10:58 AM
Leonard
May 29, 2012 10:34 AM
big l
Nov 20, 2005 08:40 AM
big l
Nov 14, 2005 07:36 AM
