Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Door lock knobs (https://www.chevyhhr.net/forums/general-hhr-4/door-lock-knobs-17103/)
budzone Jul 26, 2008 10:28 PM
Door lock knobs
Anybody else dislike these knobs. Can they be changed for different style or shaved off so they dont pinch.
ivtech Jul 26, 2008 10:57 PM
Check here:
http://www.thehhrstore.com/Smoothie_Lock_Knobs.php
JayKWills Jul 26, 2008 10:59 PM
check with mike at http://www.thehhrstore.com/ this is where I got mine!!
JayKWills Jul 26, 2008 11:00 PM
Originally Posted by ivtech (Post 295542)
Charles you were just a little faster than me!
ivtech Jul 27, 2008 12:33 AM
It's all in the timing!!
MrVette Jul 27, 2008 01:11 AM
Use the search button, you will find quite a few threads on these elbow killers.
chevyorange Jul 27, 2008 03:39 AM
Can someone who has done this tell me if it is possible to "cut" the metal lock under the plastic cover to make it even shorter? Honestly, I'd cut it down to below the door line if I could... I never plan on using the manual lock (knock on wood).
Hopefully what I'm asking makes sense. But what I'd want is when locked for the door lock to be flush/below the plastic of the door panel so you can rest your arm there with nothing poking you.
I think I might only do it on the driver's side until I'm sure I can't think of why I'd need it.
Adam
an08HHR Jul 27, 2008 07:05 AM
Adam
Yes it can be done. Read post #6 in the following thread.
https://www.chevyhhr.net/forums/show...hie#post243791
chevyorange Jul 27, 2008 05:45 PM
Thanks for the tip. Ordered my knobs, am preparing the dremmel with the carbon fiber cutting blade to try to make it flush when down! :)
Seeburg220 Sep 16, 2008 01:30 PM
I'm glad I did a search first, as I was about to start a thread about those d$%^ door lock knobs. I have lost count how many times I've had my arm pinched. WTF were they thinking!? I'm cutting mine off asap. Thanks for the info on this.
Note to moderator: how about starting a file called "HHR Fixes" or similar, and put threads like this in it? You could even further subdivide it into Interior fix, Exterior fix, Engine, etc... :thumb:
