Finally small mods
Old May 30, 2006 | 11:15 PM
dbarberaz's Avatar
Deb
Do you know the name of the glue? I think with the door not smooth and the heat here in Az I am going to need to try something else
Old May 31, 2006 | 10:39 AM
SindyDix's Avatar
I have gone through a few rolls of that chrome trim myself. I need to apply it with some other adhesive as the desert heat seems to keep the sticky from doing it job and it lifts. I end up yanking it off. I'll follow this thread to see if anyone else has this problem and have found a solution/better adhesive.
Old May 31, 2006 | 10:48 AM
captain howdy's Avatar
Superglue. It does a good job holding EL wire in place.
Old May 31, 2006 | 11:04 AM
courthousedeb's Avatar
Deb
If memory serves me right, CJ mentioned shoe goo. Here's a link to a site that has it online.
http://www.weplay.com/Shoe/Goo/
Old Jun 25, 2006 | 12:04 AM
dbarberaz's Avatar
Sindy
Due to the heat I had to remove the chrome trim a few weeks ago. Since then I bought more of it, along with some adhesive from 3M. I pit it back on one door for now. I am going to give it a few days to see how it holds. Once I see if it works I will let you know.
Old Jun 25, 2006 | 07:37 AM
  #26
cj krause's Avatar
at wal mart and other places there is a tube of 3M glue. only problem is it comes in a small tube.
Shoe goo works great but it does not have a small tip for application.
gorilla glue would work but you would have to tape the trip in place for probably 5 to 6 hours to get a good stick.
you could try a super glue gel and that may work probably the best from what i have seen on the shelves researching.
if it comes loose, dont throw it away, peel off the 3M tape on it and use a different glue
Old Jun 25, 2006 | 09:00 PM
  #27
angeleyez0072's Avatar
FYI: HHR NUT is not a he.
Daverb
Oct 26, 2008 09:37 AM
SLVR FOX
22
Jul 1, 2008 06:53 PM
SLVR FOX
Jun 10, 2008 10:25 PM
Louvit
7
Jun 1, 2008 04:24 AM
JESSE
12
Jul 13, 2006 09:49 PM
