First All Disc Panel -- SS material
Old Oct 1, 2007 | 09:10 PM
xzombiex66's Avatar
Originally Posted by hvrod
Heres what the stock brake system looks like. I'm sure you've seen this typical setup
Now the Panel is setup for Disc's in the rear, along with the better suspension components
what brand did you use for the new suspension?
Old Oct 1, 2007 | 09:25 PM
Sure...
All GM parts.... does that help ??
Did the same thing , GM is doing for the SS HHR... Using GM Stock parts...
How about come part numbers please?
Old Oct 1, 2007 | 09:29 PM
1Panel2NV's Avatar
He hasn't budged so far, we might be on our own...
Old Oct 1, 2007 | 09:30 PM
SHHHH.......maybe he'll reveal his secrets this time!
Old Oct 1, 2007 | 10:08 PM
jeffs396's Avatar
I assume the rotors are aftermarket? I've never seen slotted & drilled on a stock GM that wasn't a vette!
jeffs396
Old Oct 1, 2007 | 10:31 PM
  #26
hhrcrafty's Avatar
All you have to do is go down to the parts counter and look up the exploded diagram for the Cobalt SC/SS or the ION Red Line and it'll give you all the part numbers except for those drilled discs and blue pads. Those aren't GM stock parts.
I wonder how well those rear discs work with the stock disc/drum proportioning valve in the master cylinder?
Old Oct 2, 2007 | 07:40 AM
  #27
hvrod's Avatar
GM Suspension
( Use Cobalt its your friend too )
Old Oct 2, 2007 | 07:43 AM
  #28
hvrod's Avatar
jeffs396
GM
( Use Cobalt its your friend )
And from the pics I've seen in the HHR SS version those rotors are all solid
not drilled/slotted
http://www.crateenginedepot.com/stor...arts-C192.aspx
Old Oct 2, 2007 | 07:44 AM
  #29
hvrod's Avatar
Thats right.. Use Cobalt SS -- all disc configuration and there you go...
The Discs are also GM-- for the Cobalt....
Old Oct 2, 2007 | 07:58 AM
  #30
hvrod's Avatar
I used option 2, plus you will have to look up the brake calipers, brake cables, installation hardware,, Again use GM parts..... (Cobalt) there your friends....
