First All Disc Panel -- SS material
Old Oct 8, 2007 | 12:28 PM
  #61
hvrod's Avatar
Currently working in the engine compartment...
Larger injectors, painting parts, installing engine anti-torque device (Stiffy),
Air intake....
Next is (as I started first) stainless steel mesh screen to the lower grille and main grille area...
Upgrades to the headlights & fog light lamps change out (To yellow) ...bulbs...
Audio is later,
interior design is after that.....
Old Oct 8, 2007 | 02:18 PM
  #62
SmokinHHR's Avatar
Originally Posted by hvrod
I used option 2, plus you will have to look up the brake calipers, brake cables, installation hardware,, Again use GM parts..... (Cobalt) there your friends....
could you just use the rear axle out of a cobalt ss,or is it just as easy to buy the rotor and caliper
Old Oct 8, 2007 | 02:33 PM
  #63
Old Ray's Avatar
Originally Posted by Black Rose
So no changes needed regarding the master cylinder setup?
No... I didn't have to do anything different to my other HHR.. which is already 4 wheel disc... that vehicle I used an aftermaket kit.. no problemes.
I have been wondering about something from my old damaged brain cells (carbon monoxide) from working in the shops, didn’t disc / drum systems master cylinders have a pressure residual valve in the drum side and no valve on the disc brake side, so on a disc brake conversion wouldn’t you have to remove the valve from the rear brake port or change master cylinders?
Old Oct 8, 2007 | 03:22 PM
  #64
hvrod's Avatar
Yes. that would be your best way..
This way you can see all the parts that you need,
Find a wreck , with a good rear end and take the whole rear off with all the components on it... that will save you some $$$
Old Oct 8, 2007 | 03:24 PM
  #65
hvrod's Avatar
I did not..
I have no problems with the brakes.. all work fine...
IF I also remember right, when before I bought the kit, I asked that same question... and was told ... no... I installed the kit.. and have no brake problems.. only good stopping....
Old Oct 11, 2007 | 12:57 PM
  #66
hvrod's Avatar
Okay
another item added to the Panel (My SS version)
Light weight alternator pulley..... aaahhhhh
Wonder is GM adding this option to their SS version ?? NOT!
disconnect the battery...
You will need a 13mm wrench, 15/16 big wrench, braker bar, torx bit.
Remove your air filter assembly, relief tension to the serpentine belt, remove the serpentine from the alternator pulley, remove the (3) 13 mm bolts, disconnect the plug connection and power cable. Remove the alternator from the top hood area, replace the pulley.. Install in the reverse order...
Old Oct 11, 2007 | 10:09 PM
  #67
jeffs396's Avatar
Is this pulley just lighter weight aluminum, or is it underdrive also?
jeffs396
Old Oct 12, 2007 | 06:59 AM
  #68
hvrod's Avatar
jeffs396
Light weight only... Aluminum -- Mine is hard coated
Stock alternator weight: 6.34 Ounces
Machined alternator weight: 2.96 Ounces
Old Oct 12, 2007 | 08:41 AM
  #69
Premiere07's Avatar
MD LD9 Is the man, I have the pulley too I am waiting on the cranks to come out that way I only have to release the tensioner and take the belt off once. Are you over on the .org too?
Old Oct 12, 2007 | 08:55 AM
  #70
hvrod's Avatar
Yes on that site too..
