Flashing Securtiy System Light--Will it Run Down Battery?
Old Nov 23, 2012 | 10:57 AM
Graywolf54#'s Avatar
"The security light turns on to indicate that arming has been initiated. Once the system is armed, the security light flashes once every three seconds."
Does this light just continue to flash? I'm worried the battery will run down when in storage.
Old Nov 23, 2012 | 12:18 PM
That security light draws a very minimal amount of amperage. Not a problem for a short term storage. If you are storing it for longer than 1 month, you should check into a battery tender for your car.
Old Nov 23, 2012 | 12:20 PM
Snoopy's Avatar
Capital answer ^^^^^^^^^.
I will add, it depends on the condition of your battery, as well.
Old Nov 23, 2012 | 12:28 PM
Security light flashing
Is there a way to disingage the flashing light?
Old Nov 23, 2012 | 12:31 PM
Very true Snoopy. I just assumed since the OP's car was a 2011 that the battery was in good condition. BUT, as we know, the age of the battery is not always an accurate way to tell it's condition.
Old Nov 23, 2012 | 12:38 PM
Not easily. The security system may relay through the light circuit. Disconnecting the bulb may disable the system or not let it arm. (not exactly sure on this)
Old Nov 23, 2012 | 12:51 PM
Flashing Security System Light
Is the light SUPPOSED to continue flashing? It has been 12 hours and still flashing every 3 seconds.
Old Nov 23, 2012 | 12:58 PM
Yes..
Old Nov 23, 2012 | 02:26 PM
db/sb's Avatar
The security light flashes every second in my GTO.....
Old Nov 23, 2012 | 03:45 PM
IgottaWoody's Avatar
And it probably uses less power then your radio trying to save presets....
