Found unused wiring behind Waterfall
I had my waterfall out the other day giving it some color and a clear coat. While back there I found and extra set of unused wires. I would assume it would be for the traction control or fog lights (of which I have neither). But not sure....looked for wiring diagram couldn't find anything (that was free). Was wondering if some of you that have taken your waterfall out remember what wires went to what. there was three wires one was orange and I can't remember the other two...and if I have wires, could that mean that my rental LS might be ready for whatever option that is?
Thanks for any help given.
Did some further investigation and I have the fuse and relay in the under hood fuse panel.
What year is your HHR? They are I would say for fog lamps. IMHO With out the year I can't tell you if it has the relay & fuse. My 06 had relay & fuse also wire from BCM to under hood fuse box, The 07 did not have anything but the harness for the switch. No relay,fuse, or wire to relay from BCM.
Waterfall is a designer term as stated above because the dash flows down like a Waterfall.
They also call also the space in a Vette and Solstice between the seats in the back is also called a waterfall. THey also use the term for some grills like on some Buicks etc.
