the fuse at battery
Old Jan 24, 2009 | 12:02 PM
blkhhr06's Avatar
Unhappy the fuse at battery
for some reason my water temp gauge goes out and doesnt read sometime it does some time it doesnt. but i have found out if i go and pull the fuse out and put back in the cooling gauge works could anyone help on this and do i really need the fuse back there or could i wire it up difference?
please help.
thanks
Old Jan 24, 2009 | 12:49 PM
masterchief1112's Avatar
you really need that fuse back there. it protects your battery from being overloaded and being damaged. if you are under warranty or even if you are not i would take it to the dealership
Old Jan 24, 2009 | 01:01 PM
Lucky's Avatar
sounds like the cluster or body controler is locking up. Unplugging the fuse is rebooting the module. (like a reboot on a pc when they lock up) The next time it happens Don't unplug the fuse and take it to the dealer, they may be able to pull a code out of the system. some times a software update will fix the problem.
Old Jan 25, 2009 | 04:25 PM
HHorange's Avatar
This happened to my HHR. After a while it started setting a code too....
Turned out to be a common issue. Bad thermostat was not letting the car heat up fast enough. When that happens the computer shuts off the temp gauge. Both the analog and the digital will go out. Changed the thermostat and it has not happened again....
Hope its that simple for you too
Old Jan 25, 2009 | 05:10 PM
JoeR's Avatar
What HHorange said..
Run the DIC to read coolant temp. It should come up to 180 - 190-ish. Much lower than that, it's a bad thermostat. Common problem.
jima59
Jul 29, 2024 09:55 PM
bluedograbbit2
Mar 26, 2013 07:04 PM
longhornss
Feb 27, 2009 01:15 PM
blackout
Jun 13, 2006 11:36 PM
Lee3333
Feb 1, 2006 07:48 AM
