Garage/shop build stage 4: air, 220v, more light, insulation, hvac (PICS)
Old Jan 9, 2011 | 06:09 PM
Gas Man's Avatar
Did you put anything between your insulation and the roof? I was always told that wasn't a good idea to insulate on the roof because it doesn't let it breath.
Old Jan 10, 2011 | 09:01 AM
Redshift's Avatar
Former Sponsor
It's done to local building code. The ceiling rafters are insulated, then the "attic" space has a floor made of plywood/OSB, and the actual roof rafters are not insulated. The attic is vented to the outside.
Old Jan 10, 2011 | 03:43 PM
Krash Kadillak's Avatar
I assume you're going to finish off the walls?
I'm very envious. I finally get into a garage at my present house that's semi-useful (nice workbench and storage), and we gotta move....the new place has an attached 2-car that's just barely big enough for the cars. I'm gonna have to get real creative on storage solutions, and even make a fold-up workbench.
Old Jan 10, 2011 | 03:47 PM
Redshift's Avatar
Former Sponsor
Sure am. Just waiting a bit to get some use out of the garage, make any necessary changes/additions and then when I'm sure the layout is what I want, then I'll sheetrock and/or some combo of that and pegboard, slotboard, etc.
Old Jan 10, 2011 | 04:02 PM
weekendwarrior's Avatar
Garage progress looks great (hello from Charlotte by the way)!!!
I wanted to mention, just in general, an idea for a work bench that I had in my previous garage...but unfortunately don't have pictures.
I went to Lowes and purchased a solid core wooden door...no panels, smooth on both sides. I then put a piano hinge along one of the edges (length wise), and then attached the other part of the hinge to the wall, using 3" screws into the studs. I then bolted a set of 3" steel pipe caps to the front 2 corners, and used 2 pieces of 3" steel pipe (cut to the height you want) for the legs.
The point of this was that when I needed the space in my garage, I just popped the legs out of the caps, and the door (work bench) folded flat against the wall.
Old Jan 10, 2011 | 05:15 PM
TomsHHR's Avatar
Looking like a good MANCAVE to me!!!!!!!
Old Jan 10, 2011 | 06:51 PM
Gas Man's Avatar
Oh ok... I thought by the angles and such that you had the insulation on the roof rafters. Didn't realize there was an attic up there as well.
whopper
Sep 14, 2014 12:58 AM
Redshift
Dec 10, 2010 09:48 PM
Jacob
Canadian North Pacific
Mar 22, 2010 09:43 AM
1970judge
Dec 20, 2009 12:50 PM
SSROADSTER
Oct 20, 2008 08:10 PM
