Gas octane
Old Mar 5, 2006 | 08:17 PM
dbarberaz's Avatar
Gas octane
What octane is everyone using in your 2.4's?
They say 87 is all you should use, but I have been running 89 the last 2 times. I have nothing special under the hood, only stock. Should I go back to 87 or stay with 89?
Old Mar 5, 2006 | 08:20 PM
dan-d's Avatar
Stay with the 89, I don't have mine yet but I believe the 2.4 requires premium fuel.
Old Mar 5, 2006 | 08:23 PM
captain howdy's Avatar
Why does this keep coming up? Now comes the 10 pages of everyone arguing about what type of gas to use.
Old Mar 5, 2006 | 08:31 PM
SIHHR's Avatar
I recall this thread
https://www.chevyhhr.net/forums/general-hhr-4/premium-gas-681/
Old Mar 5, 2006 | 08:38 PM
JoeR's Avatar
Before this topic gets going too far....
RTFM !!!
Old Mar 5, 2006 | 08:48 PM
dan-d's Avatar
RTFM !!!
Thank you :)
Old Mar 5, 2006 | 09:19 PM
Lee3333's Avatar
To briefly sum things up, it is a waste to use higher octane then necessary to eliminate engine knock. That said, it has been rumored that premium gas has better additives so it burns cleaner. The cost between 87 and 93 is only a few cents, so I have been using premium.
In the same vein, I was advised by my GM mechanic who I befriended that:
a) the engine oil used is special break in type, and it is best to change it earlier than the recommended time (I plan on doing mine at about 2500 miles)
and
b) it is best to use synthetic oil, like Mobil 1
Old Mar 5, 2006 | 09:42 PM
dan-d's Avatar
and
Actually the higher the octane rating of motor fuel equates to a slower burn rate, that's why it can help to eliminate knock / ping. But using a fuel of a higher octane rating than is required to combat this condition only serves to mask the real problem. This in itself adds to polution since the fuel most likely will not totally combust and therefore will exit the tail pipe in the form of pollutants (or over work your catalitic converter). You should always use the fuel grade recommended by the manufacture. In the case of the HHR with the 2.4 it is recommended to use premium fuel.
As far as oil goes, no manufacture uses "Break in oil" anymore, that went out many years ago and what is in your car now is exactly what the manual calls for. With that said, in a new car I alway's do my first oil change at 500 miles. I do this just to get out all the crap that may be present during the break in and I replace both the oil and filter using fossil oil and a good filter. I drive another 1000 miles and then do another oil change this time using a good synthetic oil (M1) and again a new filter. After this I follow a regular oil and filter change beteen 7 and 10k.
Oh yeah, I've been doing this for over 40 years and have owned 400+ cars and have never lost an engine due to oil related issues, lost some from stupidity tho...LOL
Old Mar 5, 2006 | 09:51 PM
See I knew it was coming.
Old Mar 5, 2006 | 09:56 PM
dan-d's Avatar
So, was this not warranted?
