had trouble free use for 10 years and 80k, now no start
Old Jan 20, 2018 | 11:38 AM
This is not a deep cycle battery(nor should it be). If the battery gets discharged, and is not recharged promptly, it's life will be shortened. AGM or not, it's got to stay charged. In extreme cold, an AGM will fare better, as a discharged flooded battery is more prone to freeze.
Just trying to make sure nobody prematurely blames the battery.
Old Jan 20, 2018 | 02:34 PM
Originally Posted by Cat Man HHR
Explain how these things drain a battery?
Any loose connections will inhibit current flow, a rusty or loose ground wire especially. But a loose relay or fuse not so much.
Old Feb 7, 2018 | 11:06 AM
finnhhr's Avatar
problem solved: optima redtop battery was bad, no fault in vehicle!
got new battery as warranty.
...but noticed that waterpump leaks badly, now needs that and new cat converter. luckily had that ordered due rattle noises from exhaust.
Old Mar 17, 2018 | 10:21 PM
Wheels's Avatar
The AC Delco oem one is doing fine by me. Almost 10 years & it passes the tests
But Ive been looking into what I would replace it with, interstate comes to mind. unless local dealer still sells the same oe batttery
Old Mar 17, 2018 | 10:50 PM
Closing this thread.
Charlie Heston
Nov 25, 2015 05:15 PM
zachrf
Maintenance and Upkeep
12
Oct 10, 2014 10:09 PM
whopper
Jun 16, 2013 12:36 AM
cj krause
Aug 30, 2006 11:10 PM
