HHR FUEL FILTER replacement
Old Mar 31, 2019 | 12:47 PM
Cat Man HHR's Avatar
Abstract thinking here. Would it hurt to put a real inline filter in ?
This company says a 5 micron filter should be used with direct injection system
Read the Q&A:
https://www.deatschwerks.com/fuel-filter-faq
Old Mar 31, 2019 | 12:53 PM
It is possible, the question is why?
Old Mar 31, 2019 | 02:12 PM
Wouldn't you like added filtration before the high pressure pump and injectors ?
What's the micron filter of the sock in the tank?
Oh I know, when the engine starts to run with a miss use Seafoam, that will fix it.
Old Mar 31, 2019 | 03:42 PM
2.2 and 2.4 are NOT direct injection, no HPFP.
The fuel tank is plastic, no rust/corrosion. The only dirt in the tank is what gets past the filters on the fuel dispensing pump; most have 2 before the nozzle. Why worry about micron sized particles?
Underground storage tanks are plastic. The gasoline is filtered at the tank farm then at the pump how many more times do you want?
Old Mar 31, 2019 | 04:23 PM
Yes extra filtration would be fine, but when I changed out my fuel pump , I saw directly the fuel sock wasn’t dirty looking and there was no debris or grit in that area of the fuel pickup cup. I purchase top tier fuel same station last 91/2 years, no problems with fuel out driving the country side
Old Mar 31, 2019 | 08:41 PM
Interesting, my 1998 S-10 had an in-line fuel filter just under the drivers door in the C-channel frame rail. Easy to change.
Old Mar 31, 2019 | 10:28 PM
With a steel fuel tank and lines.
You are so last century.
Old Mar 31, 2019 | 10:41 PM
Yes, that's me, old school.
Old Apr 1, 2019 | 08:38 AM
It would be very easy to add into the fuel supply line , just a couple of fuel connections and a fuel filter, in-line under the hood, so you wouldn’t cut the metal lines. Don’t forget the crimp on clamps
Old Apr 1, 2019 | 09:26 AM
Please fix your autocorrect! "tge" is getting old now.
