Originally Posted by Cat Man HHR
(Post 831799)
Here's an idea. Maybe use a Jeep steering shaft for the added length.
It's a popular swap in A, F and G body GM cars. It might be a little long but you could shorten it. Take a look at this: https://bangshift.com/general-news/t...hed-rag-joint/ |
Originally Posted by Oldblue
(Post 831810)
This is a watts link set up,
https://cimg7.ibsrv.net/gimg/www.che...4dae059d4b.png You are showing a panhard bar setup https://cimg0.ibsrv.net/gimg/www.che...5cac3412a2.jpg |
I'm figuring since I might be loaded down some days and just cruising on others, a watts link is gonna keep my rear centered better. Am I correct in thinking this?
Your panhard setup is cheaper and just as effective
Originally Posted by RattyHHR
(Post 831817)
You should't have to worry about the left side. It's really just for traction not body roll. Right? Or do I have the wrong idea?
Correct, thats why NASCAR uses the panhard bar setup, with the driver able to adjust to control for traction
(Post 831819)
Thanks for all the advice!!
Here is a good read on what a panhard bar is used for. It explains how it can be used to adjust body roll for better traction.
Panhard Bar Explained - FMI Knowledge Base Here is another one I just found. http://buildingspeed.org/blog/2012/08/01/trackbar/ |
