The HHR and towing.
Old Aug 1, 2010 | 07:19 PM
joshua_arndt's Avatar
The HHR and towing.
I have an 06' HHR 2LT, 2.4. I just bought a pop up camper, and I am wondering if this thing will pull this. Its a 11 or 12 ft pop up when closed up. I'd really hate to buy a full size truck only for towing if i dont need to. Let me know.
Thanks guys!
Joshua Arndt
Old Aug 1, 2010 | 07:41 PM
an08HHR's Avatar
you can find a lot by using the search feature towards the top right of the forum. A lot has been discussed already. But the manual says it is only rated at towing 1000 lbs (auto tranny only, 0 for the stick) and that includes the people in the vehicle and the 6 pack you have in the cooler.
Greybeard999 will tell you the same .
Last edited by an08HHR; Aug 1, 2010 at 07:47 PM. Reason: added after greybeard999 posted after me
Old Aug 1, 2010 | 07:43 PM
You've got a 1000 pound load limit on the HHR, from what I've read that includes trailer and stuff in the back of the car. There is a 100 pound tongue weight limit. Also GM says automatic trans only.... warranty void if you tow with manual trans. Not sure where your pop-up falls in those limitations.
Old Aug 1, 2010 | 08:05 PM
I figured i'd get an answer quicker making a post. I'm lazy and didnt feel like sorting through all the posts that come up with a search. Thanks for the info though.. looks like i'll be getting a truck.
Old Aug 8, 2010 | 11:35 AM
mrarff's Avatar
Towing With HHR
Ive got a 5x8 railer (inside demension) I tow my John Deer lawn tractor (16 hp). Also if I need to haul a modest amount of lumber, it's no sweat. The really sweet thing is the roof racks.If you use a couple of 1x1 cUt to about 5', you can haul a bunch of stuff. Just use common sense and you will be amazed.
Old Aug 11, 2010 | 03:32 PM
BlindLizard's Avatar
a lighter popup. Aspen Ambassador sleeps 4 and weighs 300#s
Old Aug 11, 2010 | 08:16 PM
motoretro's Avatar
Thanks for the heads up on voiding the warranty w/ trailer and manual trans.You literally saved me 16K on deal I was supposed to do tomorrow.
Motoretro
Old Aug 12, 2010 | 10:41 AM
crazy_urn's Avatar
the owners manual (at least for my '10) also had mileage restrictions for towing 1000 lbs. i believe it was like 1000 miles per year or something, and no steep hills (not that steep hills are a major problem in OK... =D ). i would double check the manual for exact numbers, but the wife has the hhr at work...
Old Aug 12, 2010 | 12:51 PM
mrarff's Avatar
Towing
If that's the case, then towin my fat ass around for two+ years has shot my warranty to hell and back
Old Aug 16, 2010 | 06:29 PM
87silver's Avatar
You need an ultra-lite unit, like those from Quicksilver.
Specs on Pp 3
http://www.livinlite.com/pdf/2010QSFP.pdf
