I want to put fog lights in
Old Mar 26, 2009 | 10:07 AM
GrotesqueFetus6's Avatar
Does anyone know how to go about this?
I have a 2007 panel LS with the spots to put fog lights.
I like the lights down there but I don't know anything about wiring and putting lights in
And while on the subjects of lights. How about the true light bulbs for the headlights and the LED lights for the rear. Does anyone know where to get those?
Old Mar 26, 2009 | 10:33 AM
an08HHR's Avatar
try the search feature at the top of the page. One thread that turn up is https://www.chevyhhr.net/forums/show...t=install+fogs
I would suggest you have help if this this stuff is new to you, experience is also good.
Old Mar 26, 2009 | 10:58 AM
Thanks. Yeah I know for sure ill need help or someone there that knows everything and would be watching over to make sure I do nothing wrong. Now that's the best way to learn haha.
Old Mar 26, 2009 | 11:08 AM
gcsd3742's Avatar
why dont you just run the HID's alot brighter and they use less wattage as well....
Old Mar 26, 2009 | 11:35 AM
NxlKing2304's Avatar
I'm actually doing this to my 2007 LS. I will have this completed in about a week. I must warn you though, I do things the proper way, meaning getting the actual GM Parts, Connectors, Terminals, and wire it the same as factory. It takes a little longer, but looks more professional and looks neater.
Goto GMPartsDirect.com to get all of the part numbers needed, I wouldn't buy from them though. goto partszoneonline.com to order. They have excellent customer service!:
You should need:
LF Fog Light Assembly = GM#15813307
RF Fog Light Assembly = GM#15813308
Fog Relay = GM#19116057
Fog Switch = GM#21992589
Fog Light Connectors (Need 2) = GM#12101898
Fog Light Connector Terminals (Need 4)= GM#12077411
If you want I can email you with all of the diagrams as they are in .pdf format.
Connecting To the Fuse Block you would need terminals, or run the wires yourself. All GM Parts numbers above fit my 2007 LS, but may not be correct for your specific application. I can send you any diagram you need for the fog lights, as for wiring I can help you figure it out, but your ultimately responsible. My New fog lights are going to be HID bulbs I got from xenoneyes.com. I already have HID's for my headlights that are Dual-Beam. My new Fog Lights will be Single Beam 10000K to match the color temperature of my headlights. I hope this helps.
Old Mar 27, 2009 | 06:39 AM
solman98's Avatar
This should help with aftermarket wiring....
https://www.chevyhhr.net/forums/show...ghlight=lights
You can also use this for the factory lights themselves. That what I did at a later day.
Old Mar 27, 2009 | 07:37 AM
09 Panel's Avatar
NxlKing2304
I'm thinking of doing this except I'm just going to wire the input power to switched 12 volts so that the fogs can be turned on and off at will. I'd still like to use the OEM fog switch though. Your part number for the switch is for what part?? I have no space on my dash for the switch so I assumed I would need a new trim plate and the switch too. Is that correct??
Old Mar 27, 2009 | 08:27 AM
Originally Posted by 09 Panel
NxlKing2304
Well, you should have space for the fog light switch like OEM, you should put your switch there. It would look a lot nicer. You can still get the connectors and terminals for like a few bucks so you have a tight fit for the fog lights, ad then wire them from there. If you need any other help, PM ME!
Old Mar 27, 2009 | 08:37 AM
09 Panel's Avatar
If I'm not mistaken the switch should go between the traction control and the airbag light on the dash, right?? If so I would have to get a new trim plate too I guess since mine is solid.
Old Mar 27, 2009 | 08:41 AM
Can you post a picture?
