door popers
Old 02-06-2009, 01:10 PM
longhornss's Avatar
door popers
Just wondering if anyone has instaled a set of door popers from a panel on ther non panel.
longhornss is offline
Old 02-06-2009, 01:52 PM
masterchief1112's Avatar
itd be really hard to get them to work. you would prolly have to have the pcm programmed with the panel firmware. doubt they would do that. on top of that i am also highly doubting the wiring for them is there. if you wanted to do this i would say that you would need to use an aftermarket popper.
masterchief1112 is offline
Old 02-06-2009, 02:49 PM
HHorange's Avatar
While trying to do a full factory style install would be costly at best. It should be faily easy to install the factory door poppers and then wire them to aftermaket controls. Of course if you have to have aftermarket contols you might as well just buy a full aftermarket kit. That would most likely be the cheapest way to go.
HHorange is offline
Old 02-06-2009, 03:01 PM
ChevyMgr's Avatar
I agree with this!
And also you can't reprogram the BCM to think it is a panel.
ChevyMgr is offline
Old 02-06-2009, 03:50 PM
Restlessone's Avatar
Door Popers
At the risk of sounding stupid, what are door popers
Restlessone is offline
Old 02-06-2009, 04:18 PM
ChevyMgr's Avatar
They automatically pop the back two doors open.
ChevyMgr is offline
Old 02-06-2009, 04:38 PM
djnixtre's Avatar
Sorry Mr. Moderator, I noticed you've removed my post and someone elses here. No room for horribly bad humour?I guess that was bound to get out of hand.
djnixtre is offline
Old 02-06-2009, 06:07 PM
1Panel2NV's Avatar
An aftermarket kit would be best. The stock door poppers aren't the best.
1Panel2NV is offline
Old 02-06-2009, 11:40 PM
Lucky's Avatar
I was informed by the dealer that the 08 panel rear doors have there own module that controls the rear remote doors only. when I had work dune to my panel they had to reprogram the key fobs. when I got the car back the rear doors would not work with the key fob but the front doors worked fine. was told then that they had to reprogram a rear door module. so if this is true my be fairly easy to add on.
Lucky is offline
ecl
17
06-25-2013 04:38 AM
skyline26
03-15-2013 08:25 PM
Leonard
05-29-2012 10:34 AM
Showgun
12-06-2007 07:17 PM
Quick Reply: door popers
