Installed the Rear Anti-Sway bar tonight
Old Sep 16, 2007 | 04:35 PM
  #41
hhrcrafty's Avatar
Originally Posted by Lone Ranger
The stock "axle" linkage looks pretty stout. Does it really allow that much sway such that a bolt-on anti-sway bar makes a difference?
Shhh!
Move along, nothing to see here...
Old Sep 16, 2007 | 04:59 PM
  #42
Goose's Avatar
Originally Posted by jx3
The box mine arrived in states that it is only 15 lbs. (according to UPS label).
Feels like 30-40lbs when trying to balance it with one hand! I know it felt even heavier for me. Didn't even think of a c-clamp or zippy tie
Goose
Old Sep 17, 2007 | 08:50 AM
  #43
Got mine installed yesterday afternoon! Install time from breaking out the ramps to rolling off was not even 10 min.
Noticable difference when driving Turnpike back home, definately didn't want to "roll" in the wind, and the on ramp to the pike from 75-----was able to keep it true in the turn at 80 MPH, didn't have to brake or turn cruise control off!
Let's not forget to mention the HP gain from installing the bar either
Old Sep 17, 2007 | 09:48 AM
  #44
Black Rose's Avatar
I thought it was the stickers that added the HP, or is that only when you add "Type R" stickers?
Old Sep 17, 2007 | 09:54 AM
  #45
Any decal is worth at least 5 HP.
Old Sep 17, 2007 | 11:30 AM
  #46
jescobe82's Avatar
I was considering a rear anti-sway bar on my '07 2LT. I just got done looking at the rear suspension, and it appears mine already has one from the factory. There is a bar running across inside the rear "v" channel axle. It's hard to tell what size it is, but a guess is about 5/8". I have not heard of anyone with a "factory" bar installed. If this is not an anti-sway bar, then what is it?? ANYONE??????
Old Sep 17, 2007 | 08:14 PM
  #47
Hotrodbob's Avatar
I think the 2LT have rear bars. I looked at mine and it does to. have those people that have installed the new bars left the stock one in place?
Old Sep 17, 2007 | 08:24 PM
  #48
If there was one already there, it is still on as nothing came off when installing.
Old Sep 17, 2007 | 08:30 PM
  #49
john 11's Avatar
HotRod
Here is a quote from a previous thread. I put the anti sway bar on my 2LT and it made a big difference.
Originally Posted by SoCalHHR
Yes, ther is a round bar inside the torque tube, it is there to "stiffen" the torque tube but does not work the same as a separate sway bar. The Progress Anti-Sway bar bolts to the "lever" end of the spring pad, and is kept "mechanically" separate from the rest of the torque tube (it does however, fit up inside the tube). This allows it to provide maximum resistance to inside wheel lift. It does work in conjunction with the existing torque tube - and greatly decreases rear end sway.
The entire thread is: https://www.chevyhhr.net/forums/show...p?t=934&page=4
Old Sep 17, 2007 | 08:44 PM
  #50
Hotrodbob's Avatar
Great! I was thinking it might make it to loose with both
