Installing used factory seat belts and back seat in 2010 panel
Old Dec 4, 2017 | 08:15 PM
Any auto parts store has them many have them to loan.
AND some NON-SILICONE anti-seize compound.
Old Dec 4, 2017 | 08:37 PM
Ohirolina's Avatar
Great! Thanks
Old Dec 5, 2017 | 10:41 AM
The sensors are 7/8 inch , crack them loose while the pipe is attached , more leverage, or remove them on the floor after
Old Dec 5, 2017 | 05:01 PM
Ohirolina's Avatar
Thanks for the tip!
Old Dec 6, 2017 | 04:07 PM
Grizzly old man's Avatar
When I replaced my exhaust pipe the leads on the sensors were way to short to reach the ground. I suppose you could unplug them but I went to Harbor Freight and bought a set of O2 sensor sockets for around $15.00;
Mine go on a 3/8ths inch ratchet but an open end wrench will work as well as the sockets. I have been replacing all my tools, mostly at Harbor Freight. My dad was a master mechanic at a few different Ford garages while I was growing up and when he died I got his tools.
I used them for years when I had my own shop.
I am sure if he could come back for just one day he would spend most if it kicking my ass up and down the street for what I did to his tools.
Old Dec 6, 2017 | 04:18 PM
I bought the HF 3/8 Drive 7/8 sensor socket but it wouldn’t fit in there with the ratchet.
I disconnected both sensors, I can get to them from up top with the stock air box removed.
My exhaust manifold flange nuts are 9/16, it might be from heat cycles but a 15 mm 6 point was loose on them.
PB blaster helped .
I always drive about 10 miles to warm up those nuts , I can also crack them loose from up top after removing the air box
RJ_RS_SS_350
Mods - Interior
7
Apr 3, 2017 09:38 PM
Mrs. DLVRNIT
27
Nov 30, 2011 04:32 PM
