Socket/connector failures are directly linked to "operator error". If they are not connected properly they arc and overheat.
The other times I replaced the harnesses it was shortly after buying the vehicles. I like to use contact cleaner and die electric grease when connecting anything going outside but that doesn't always guarantee that it will prevent issues
Now it went from one headlight (both high and low beam) to both headlights. I lost both headlights while driving to work this morning and I had to use my fog lights to drive. I went through and checked everything when I started experiencing the drivers side going out and everything seems to be fine. I'm starting to lose my patience with this car and it sucks because I like it but for only having 66, 000 miles on it I should not have to be continually wrenching on the thing
