Just a thought
Old May 9, 2018 | 09:25 PM
Snoopy's Avatar
Seems strange you need to do this. I'm in Arizona with temps exceeding 100 degrees and mine cooled down to an comfortable level in about 15 minutes. Are you sure your AC is working correctly. Note....vehicle has been sold to a friend and he finds the AC very comfortable,,,still.
Old May 9, 2018 | 10:09 PM
Thumbs up
Snoopy- very good point.
Old May 11, 2018 | 09:24 AM
You know about the floor level vents under the front seats that blow to the passenger compartment? I can't remember if they only work in heat mode or not.
My A/C always threatened to freeze me.
Old May 11, 2018 | 10:31 AM
Cat Man HHR's Avatar
Educate me. I've looked under the seats to clean and haven't seen what your explaining.
As a side note, I have use a thermometer as a test. With the AC on recirculate and on low speed fan after I have given ample time for the interior to cool down, the temperature out of the ducts is 45*, but take the thermometer and hold it by my chest and it can read 75-80*.
If there was a partition to block off the back half, the seating area would have a better chance of maintaining a cooler temperature.
As I said, this is a thought (a.k.a. science experiment).
And yes my system is functioning correctly.
Old May 11, 2018 | 11:11 AM
Old May 11, 2018 | 11:21 AM
ICT_GG's Avatar
Pick up one of those clothing hangar rods they sell that attach to each hanger in the back seat, grab a clear shower curtain liner and a set of cheap plastic curtain rings, and you'll be good. Trim it down to whatever size works for you. Should be able to do it all for $20 or less.
Old May 11, 2018 | 06:50 PM
Blue_SS's Avatar
Your AC is under-performing. Maybe just top it off?
Old May 11, 2018 | 08:21 PM
X 2, Should be colder, & my Panel floor level rear vents blow cold with the A/C. I think I could make ice cubes in mine.
PS: Great pic firemangeorge. I remember seeing it many years ago, then I lowered my front seats same way.
Old May 11, 2018 | 08:38 PM
J W Davis's Avatar
I live in Texas and it gets very hot in summer, note that the car is black also. However, I get so cold in our HHR that my ears burn like cold wind in winter.....I just can not understand how yours is not cooling like it should.
By far the coldest A/C of any vehicle I have ever owned.
Old May 13, 2018 | 08:57 AM
Casa Del Gatos's Avatar
Vent visors in all the windows. Leave windows cracked a bit.
Leave A/C on best settings when getting out. Then remote start 5 minutes before you leave.
Works great for me. Of course, if you are manual, this does not work!
1970judge
Nov 8, 2010 02:07 PM
urbexHHR
Oct 24, 2009 04:55 PM
ecl
Aug 7, 2008 08:53 PM
Daverb
Feb 6, 2008 09:16 AM
Firewatcher
Dec 22, 2006 05:20 AM
