Keyless entry help
Old May 30, 2013 | 11:39 AM
  #31
ramo5150's Avatar
Originally Posted by mrsilent13
i got the same thing as the op....just one key no fob and i just looked and saw that it does have an AP3 code...and i also found these instructions on another site...do you guys think this will work? also what is the part number for the remote with the remote start?
http://chevroletforum.com/forum/showthread.php?t=20695
Keyless Re-program Instructions
Legend:
Insert key and turn ignition switch to "On"
Follow these steps:
-Press Vehicle information button until "PRESS [checkmark] (set/reset)TO RELEARN REMOTE KEY" displays.
-Press Set/Reset button until "REMOTE KEY LEARNING ACTIVE" displays.
-Press and hold both the Lock and Unlock buttons on the keyless remote for approximately 15 seconds. A chime will sound to indicate that the remote is programmed.
-To program additional remotes, repeat step 3. A maximum of 8 remotes can be programmed to this vehicle.
-Exit programming mode by turning key to "Off" position.
-Test Remote(s)
Hi Everyone,
New to this forum and Just wanted to say HI and ask a question..
Has any one tried this or figured out how to program their fob?
I know that it doesn't need to be taken to dealer cause a while ago, my 70 yr old dad to it in to get fob reprogramed and he was sent to a tech(who thought that dealer charging $70 for reprogramming was a rip off) and he showed him how to do it but he doesn't remember the procedure. He said it can b reprogrammed without having to go to dealer and paying.
Thanks in Advance....
Old May 30, 2013 | 12:36 PM
  #32
Welcome to the site ramo5150. I just took the ones I bought second hand to the Dealer to program both sets, charged me 50.00, but I bought the trucklet from them.
Old Jun 9, 2013 | 04:30 PM
  #33
Joyzee31's Avatar
Hello... I am new to this site also.. And just purchased a 2006 HHR... And only the unlock works on the key fob... I did try the foil and then the remote went a lil crazy...unlocking and locking every time I moved the remote... So my question is... Has anyone tried the replacement Fob from eBay?? I saw they have fun colored ones on there.. For pretty cheap... So thought I'd ask on here first...
Thanks for any help
Joy
Old Jun 10, 2013 | 09:59 AM
  #34
Originally Posted by tech-guy
Hello Guys,
I need some help. I just bought a 2009 HHR LT about 3 days ago. It was pre owned so all I got was the keys. The sales man told me that he believes the car could have a keyless remote but he is not sure since the previous owner just gave them the keys. I want to know if there is a way to find out if the car already comes with the keyless remote or not... The car has automatic door locks and automatic windows..What shocked me from this car is that the passenger side does not have a key hole so this weekend when I took my girl out I looked like an idiot trying to manually open the door on her side only to find out there was no keyhole it can only be opened from the driver side...
Thanks
John...
Hey John,
I can look into your concern to see what options you may have available. Just private message me your full name, address, vehicle identification number, and current mileage. Thanks
Jessica L.
Chevrolet Customer Care
Old Jun 10, 2013 | 10:59 AM
  #35
Thanks for any help
Joy
They sure have - use the SEARCH facility and look for KEYFOB (one word) - there are lots of postings over this issue.
Re: foil fix on your fob - pull it apart and take another look at it as the fix does work if done properly.
Old Jun 10, 2013 | 11:01 AM
  #36
Originally Posted by ChevroletCustomerService
Hey John,
Jessica L.
ahhhhhhh - that posting you refer to was from way back in 2010 - it's very doubtful you will be getting a response.
Old Jun 13, 2013 | 12:05 PM
  #37
sjac940939's Avatar
Oh, having problems with my key remote. It has gone out, and now that I lock the HHR manually, sometimes the key will not unlock the door. ARGH!
Old Jun 13, 2013 | 07:14 PM
  #38
Really sorry to hear this. Could you please private message me your name, address, vehicle identification number, and current mileage. This will allow me to look into the features on your vehicle.
Thanks,
Jessica L.
Old Jun 13, 2013 | 08:24 PM
  #39
I was just to the point of complaining that my fob was not locking the car everytime. I replaced the pad and cleaned the contacts, still only locks sometimes. My old 2008 worked fine, the 2011 is finicky.
Then I read a tech note about something that referenced GM changing timings in some of the BCM functions. Tried holding the "lock" button for a a full second not just a tap, THAT WORKS EVERYTIME. Could this also be the solution to the "remote start doesn't work" problems? I don't have RS so I can't test it.
Old Jun 13, 2013 | 08:28 PM
  #40
Originally Posted by ramo5150
Hi Everyone,
Your 70 year old dad did not have an HHR, did he? Yes that will work on SOME cars, not HHRs.
