LCA differences
Im not sure, thinking to just stay stock and put new shoes on the rear too, they seem worn ( e brake pulls high ) and braking seems fronts do all the work? Will probly throw new shocks /struts on as well
Yeah I know, but with 200+K on the car I dont know if they were ever replaced so going to have them looked at and replaced if they need to be. My front pads are new but the caliper on drivers side is c ocked from top to bottom so not sure if its from the worn pin that was siezed, I cleaned and lubed it but its still apparently sticking on the pin or something is bent ( bracket maybe ) Im not showing any accidents but not sure whats going on with it? so just going to replace with new.
My idea is order front loaded calipers for 2009 SS non Brembo and rotors, that gives you new calipers and brackets and the larger rotors with pads and all hardware
https://www.rockauto.com/en/catalog/...+pad+kit,14204
DangerBoy
71
May 20, 2026 11:58 AM
mrgreen73
18
Aug 6, 2018 04:54 PM
DwHhr2LT
Sep 29, 2012 08:25 AM
