Lug Nuts
Old Jul 30, 2018 | 08:02 PM
Ron S's Avatar
Lug Nuts
I just picked up a set of 17" factory alloys, from a 2007. Do the need special lug nots or can I use mine from my steel wheels on my 10?
Thanks
ron
Old Jul 31, 2018 | 07:49 AM
A nice black set should look awesome
https://www.chevyhhr.net/forums/clas...ug-nuts-59206/
or use your old ones
Old Jul 31, 2018 | 11:59 AM
Cat Man HHR's Avatar
Buy chrome or black don't use the OEM on them. Gorilla brand is my first choice.
Old Aug 1, 2018 | 05:31 AM
Ron S's Avatar
So those are just covers that fit over standard lug nuts. My stock ones have external threads on them. These threads are how the hub caps are attached.
Old Aug 1, 2018 | 06:49 AM
No the Gorrilla lug nuts are all steel lug nuts.
Old Aug 1, 2018 | 07:55 AM
Gorilla Automotive Products
Old Aug 1, 2018 | 08:03 AM
The plastic covers are part of the wheel cover.
I am not sure but most alloy wheels use a special lug nut.
Old Aug 1, 2018 | 08:36 AM
The RockAuto site shows these 17 inch alloy wheels to have a tapered seat for the lug nuts.
Note the recess hole might be to small for lug nut caps.
You could order this style cap to thread onto those double threaded lug nuts
These are from Dorman and are for a Pontiac Firebird from the late ‘80’s, but might not fit your alloy wheels.
Old Aug 1, 2018 | 05:55 PM
Blue_SS's Avatar
It depends on the seating surface for the nut. Most OEM alloy wheels still use steel lug nuts with fancy covers. Use OEM for OEM-style wheels, unless you know they are different. Look for a conical taper.
Actually, compare your old ones to the new ones. If they look the same, you are good to go. The difference is obvious, if there is one.
Old Aug 1, 2018 | 09:15 PM
My 17" polished factory upgraded QP2 alloy rims use chromed steel nuts, they have a 60* taper, & threads are same 12mm x 1.5
