Mexican amount worth of HHR?
The last post. Having problems identifying location of where this "spliced/soldered" wires are.
https://www.chevyhhr.net/forums/showthread.php?t=28496
Attachment 13539
SSfan. Interesting to see our pictures next to one another. It shows the difference in clearance between the 2. Mine seems to have a lot more clearance than yours. Or maybe it is just the angle of the photos.
Either way, both of ours show a way to fix the compressor/Tmap rubbing problem.
I knew someone would answer the call.
The space can vary based on where the IC is bolted in or even how far the hose is pushed on. The IC location is not exact on all SS and can be more forward or back depending on where the brackets are locating it.
