mufflers?
mufflers?
I'm going to make a dual exhaust setup. Trying to figure out which mufflers I need to get. Which one will work best inlet in center and outlet offset or inlet and outlet both center. Little help. Thanks
im going to use an oval muffler. I thought about the ones you have but I dont want it to be too loud. I just want a good tone. I just dont want to order an offset muffler and have a problem on the passenger side thanks
I would sell them both very cheap if interested. They are still brand new in the boxes.........Mufflers only, no exhaust tips....PM me if interested.....Regards
BTW...The tips are off a Corvette Corsa exhaust that his friend had lying around.
When I was going to do my duals, I talked to this guy and he told me they were IMCO mufflers. To make a long story short..... I bought the same mufflers in the picture and never used them.
good deal. I think I am going to go with stainless mufflers thanks for the offer though. I see in your pics you changed your air intake, what did you use? It looks like it goes to the driver side of the engine.
That is the remains of an old CGS setup (that totally sucked in my opinion)....I cut out the important piece (mass air connection) and ran it toward the drivers side like that when I installed the nitrous. What you can't see is the cold air tubing that comes up from the gap on that side of the engine compartment to the filter....Regards
