Needing a little help!!(Rear speaker change)
I'm sorry if there is a post already floating around here on this but I couldn't find it....But I've done a little research and I've seen alot of people having the same issue I'm having in my LT...The dreaded cheap speakers go in and out, and when they are out only the tweeters work...Well I went and took the drivers side door panel off just to find out I needed an mounting bracket for the front speakers...so I've ordered them already...but now I wanted to see is the same bracket needed for the rears speakers also? Any help would def be appreciated!! Thanks
Aaron
Aaron
I do believe they are the same brackets, and when I did my speaker swap, I just cut out the old speaker and basket and kept the "ring". New speakers fit right in with no aftermarket brackets needed. Hope this might help you out.
Cheers.
Cheers.
