New Smooth Lock Covers
Here is something I found on a Camaro I judged at a Camaro show. The guy who owned the new Camaro sells them. It is called a Smooth Lock. It is a piece similar to the door handel that stick on you key lock that you never use if you have a remote entry.
It is small but cleans up the door handel look. I like small details that look stock but clean up the look of the factory piece. He does not show them on his web site for an HHR since mine was the first one he tried to fit. I though some here might like this for a cheap and easy upgrade. Also you only need one for the HHR. He sells them direct so you need to contact him direct. http://www.smoothlock.com/ http://img121.imageshack.us/img121/638/dsc01389y.jpg http://img87.imageshack.us/img87/7655/dsc01388e.jpg If you need the lock you can jut pull it off if needed. |
Might actually be enough to thwart someone who got your key but didn't have your fob. "OMG this car has no locks....dude...." :nuts:
Awesome i really like these. i have seen some in the past the were flush with the handle, but didn't look right. Nice find!!!
That's pretty tight... do you know what size we need if we wanted to order one?
Looks like you painted a dime black and glued it in there.
Originally Posted by a76marine
(Post 415150)
Originally Posted by Jeff®
(Post 415166)
If you have anything but black I think you need to paint them. That shoulld not be an issue. Spray or Brush should work fine since it is so small. |
